Author Topic: Starting issues 2009 650  (Read 204 times)
Offline Plainemu
  • Bike: DL650A,Katana1000,Katana1100,Katana650
« on: May 05, 2024, 12:22:16 »
Came out to garage this morning . Switch on fuel pump primed ,hit starter . Nothing just the front lights dimming . No clicking etc bumped it off first time no issue at all . Ride out came back and same again . Priming and Dim lights . Am thinking it’s battery related . I have 12.1 V showing across the battery but nothing . Got to wait until neighbour comes back back to bump it off again and get a reading when running . Wanted to check to see if I should be looking elsewhere but battery
Offline crump
Re: Starting issues 2009 650
« Reply #1 on: May 05, 2024, 12:33:45 »
12.1 isn't enough I don't think, needs to be 12.6 minimum I think.......tbf I am an electrical numpty.
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
Offline nigel s
  • Bike: DL650A M2
« Reply #3 on: May 05, 2024, 14:27:42 »
A fully charged battery, left for an hour to settle should read ( in an ideal world ) 12.6 volts.
12.1 is on the low side.
Offline Plainemu
« Reply #4 on: May 05, 2024, 15:06:20 »
New battery on order so will keep you all posted . Thanks for the reply’s much appreciated
« Reply #5 on: May 05, 2024, 16:42:38 »
My Money is on a battery being past it's best.
As has been said, anything below 2.4 volts, either needs to be charged if it's been stood for a while or a sign it's dyeing.
My guess would be if you read the voltage while hitting the starter, the voltage will likely drop into 10v  or under. - eg a battery cell failed.
MDS Batteries have been my go to place online for various batteries for years.
Often cheaper inc postage than the local places are to pick it up.
But I also pick up Motobatt batteries from M&P's as they're local and will price match
Offline Plainemu
« Reply #6 on: May 08, 2024, 08:54:03 »
New battery left overnight on Tender . Fitted this morning and boom away she goes . Thanks for the support everyone
Offline crump
« Reply #7 on: May 08, 2024, 09:19:54 »
Always nice when it's an easy fix.
