Givi trekkers outback pannier Rack
Topic: Givi trekkers outback pannier Rack (Read 837 times)
Woodyflyer
Bike: L5 Glee, Bandit 1200, Burgman 650. 1050 RR
November 21, 2023, 06:02:48 »
I'm thinking of fitting Givi rack PL03118CAM and a pair of 37litre Givi trekker outback pannier, on my 2023 1050 RR (cast wheel model ) If using this rack does anyone know if the exhaust side case mounted is offset or the same spacing away from the bike as the chain side??
I want the cases to sit as tight to the bike as possible...like the factory cases do.
Cadbal
Bike: DL1000
Re: Givi trekkers outback pannier Rack
December 18, 2023, 21:37:21 »
I have this rack on my 2018, I have the 48L? side cases and can post a pic if you want to see how they look, but they aren't offset, the right side case sits slightly higher than the exhaust and has the same clearance as the left side
Woodyflyer
December 18, 2023, 21:45:44 »
Thanks for the reply, a picture would be great
🙂👍 I've got a 650, the off set just doesn't look right.
Cadbal
Bike: DL1000
December 21, 2023, 19:27:16 »
I'll try to get a pic before xmas for you, manic time of the year
