Author Topic: ACF50 Application?  (Read 5346 times)
Offline grumps
  • Bike: DL650A M0, BMW R1250RT. Yamaha X-Max 300
ACF50 Application?
« on: July 11, 2016, 17:49:12 »
The pretty useless applicator supplied with ACF50 has split.
How do you apply it in quite small quantities? I don't have an air sprayer.
Thanks
David
If money can't buy happiness - explain motorbikes and beer.
Offline grumps
Re: ACF50 Application?
« Reply #1 on: July 11, 2016, 18:23:47 »
I should add that some places I want to apply are not easy to get at witha cloth or brush - like up the top of the shock on my lad's Divvy 600
« Reply #2 on: July 11, 2016, 18:48:47 »
B and Q squirty bottle?
« Reply #3 on: July 11, 2016, 19:26:03 »
+1 what tall Paul said bottle for spraying plants.
Offline grumps
« Reply #4 on: July 11, 2016, 19:35:12 »
Ah...I'll try one.
Thanks
Offline Moo
« Reply #5 on: July 12, 2016, 22:15:30 »
I found it too thick too spray in a squidgy bottle...
« Reply #6 on: July 12, 2016, 23:15:18 »
Me too, a compressor is the way  :smirk:
« Reply #7 on: July 13, 2016, 00:32:11 »
Me too. I use a compressor now, although it's quite difficult to get the spray amount and pattern right. IIRC, a 1.5 nozzle in a gravity fed paint gun is best, with the pressure right down. As an aside, I also tried using a paraffin gun for applying S-DOC 100 and whilst it certainly did the job in terms of coverage I very quickly went through a whole bottle's worth in one application, which is a tad expensive!
Before I bought a compressor I had the same problem with the supplied bottle eventually giving up the ghost. I eventually found that a chef's olive oil spray was the best (like this one for £3.50: http://www.ebay.co.uk/itm/Stainless-Steel-Olive-Oil-Bottle-Mister-Spray-Spraying-Sprayer-Pot-Cooking-Tool-/111470160065) since its designed to spray viscous liquids like oil (whereas the garden sprayers aren't designed to spray anything more viscous than water).
Offline grumps
« Reply #8 on: July 14, 2016, 15:28:13 »
That's a thought Simon - thanks.
I don't really want to invest in compressed air. I know what will happen - shot blasting gear, paint spraying gear, tyre inflation ........it would never stop!
« Reply #9 on: July 14, 2016, 22:41:33 »
Grumps, I've read your reply a dozen times but I still can't see what the problem with buying a compressor is  :)
« Reply #10 on: July 15, 2016, 10:17:17 »
All sounds positive to me too!
« Reply #11 on: July 15, 2016, 20:30:34 »
Empty wallet is a negative.
More time away from the family while you play with new toys, negative or positive based on if you like your family or not.
Offline grumps
« Reply #12 on: July 18, 2016, 17:45:02 »
I know what I mean, it would be a slippery slope
« Reply #13 on: July 18, 2016, 18:00:52 »
Does dunking the plastic squirty bottle in a bucket of hot water help the ACF50 to spray any easier? Or is it just that when you do it with a spray can, the propellant expands and gives it a bit more push?
« Reply #14 on: July 19, 2016, 13:09:41 »
Put it in hot water and it works a lot better at spraying seems to go further as well.
