Author Topic: Which Oil?  (Read 2969 times)
Anonymous
Which Oil?
« on: May 18, 2008, 17:43:48 »
Deleted
Re: Which Oil?
« Reply #1 on: May 18, 2008, 18:19:01 »
Well the manual states SAE 10w/40w semi synthetic I believe
Offline pebble35
Re: Which Oil?
« Reply #2 on: May 19, 2008, 08:04:17 »
10/40 semi synthetic is fine - as recommended by Suzuki.
I always used Putoline Sport 4 and had no problems (inc one 11,000 mile trip without an oil change or even needing to top up the oil  :o ).
Be aware that it is not just the grade of oil that matters (ie the 10/40 bit).  You will find that oil has an 'SAE' or 'AP' specification as well and motorcycle oil will be a different spec to car oils - different additives (particularly as a bike has a wet clutch which runs in the engine whereas a car will have a dry clutch).  Some of the additives in a car spec oil may give you clutch problems.
At the end of the day you do not need the super expensive top of the range synthetic oil - but at the other extreme I would not swant to save a few pounds by buying the cheapest stuff out there - the choice is up to you.
Shop around and do not be afraid to ask for a bit of a deal on a reasonable quality oil.
Hope this helps.
Anonymous
Re: Which Oil?
« Reply #3 on: May 19, 2008, 08:39:04 »
Deleted
Offline Urban Tangleweed
Re: Which Oil?
« Reply #4 on: May 24, 2008, 17:04:14 »
As I understand it, Stroms (both Wee and Vee) just need a good quality 10/40 oil.
You can use car oils if you like, but you mustn't use any with friction modifiers or, "eco" oils as these may do the clutch in.
Better to use motorcycle specific, but no need for fully synthetic, semi or even regular "Dino" oil is fine as long as it meets the required specs.
I was in our local Hein Gericke the other week, and they had their own brand oil at £13.00 for a 4 litre container, I'd be quite happy to use this, and it's a good price.
Just my tuppence worth.
V Strom 1000 - Ride the Thunder !
Offline Piglumps
  • Bike: None at this point
Re: Which Oil?
« Reply #5 on: June 14, 2008, 11:26:40 »
Has anyone tried Magnatec or similar? I've used it in the car for years with no ill effects....Mike
No bike at present.......
Offline stonehenge
Re: Which Oil?
« Reply #6 on: July 05, 2008, 18:32:47 »
You need to use motorcycle oil due to the shearing effect of the gears in the gearbox - the oil is for the engine and box combined.  Use a quality semi not fully synthetic to save any clutch slip problems.  I find that the red Castrol oil gives the best gear changes.
Steve
Previous: GS850, Thundercat, Honda X11, Transalp, VFR 800, GSX750x2, RF900, XT600, Mille, K2 Vee, K6 Wee, K7 Vee, 955 Tiger, BMW1150GSA, Honda CB250RS, BMW R1200RT, Honda XL650V Transalp, 2012 R1200GS, 2015 and 2016 R1200GSA, F750GS, F850GSA, FJR1300A, G310GS, Benelli TRK502, Now DL1050A
Offline MR TiGGer
Re: Which Oil?
« Reply #7 on: October 02, 2008, 23:25:29 »
Not as I understood it Steve, I was led to believe that modern Car oil has special additives that reduce friction inside the engine which is rather a bad idea with a wet clutch system that most motorbikes have, hence the need for a separate oil, but yes semi-synthetic to protect the clutch.
(As I understand it, no offense intended)
And Putoline in my beastie <!-- s:mrgreen: -->:mrgreen:<!-- s:mrgreen: -->
Grrr:-)
Grrrr:-)
Previously: K7 DL650GT [Stolen by wife] K6 DL1000GT, CBR600F-V, DT-125, ER50
