Oil/Lubrication
oil level
Topic: oil level (Read 3600 times)
kenww
oil level
March 21, 2015, 09:00:15 »
Hi,
Prior to first trip of the year checked oil as per owners manual,then it says check daily by looking in window.
What's wrong with oil visible whilst centre stand?
MartinW
Administrator
Bike: DL650 K4 Blue
Re: oil level
March 21, 2015, 10:12:56 »
The oil level in the sight glass window will only read correctly when the bike is standing upright on it's own wheels.
The side and centre stands both tip the bike one way or another.
greywolf
Re: oil level
March 21, 2015, 11:12:27 »
The centre stand will make the level read a bit high since the glass is in the front part of the engine. A proper reading at the full mark will show a minimal trace of air above the oil on the centre stand.
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Re: oil level
March 21, 2015, 12:03:37 »
I've always checked my oil on the centre stand on a flat surface. I figure it's more accurate than trying to keep a bike upright while bent over to look at the glass. There's also no chance that the bike is going to fall over when you have it on the centre stand than when you're holding it. The centre stand makes the bike lean towards one side so if you're really concerned about the slight inaccuracy then put something under the front wheel and the one centre stand foot to level the bike and see how much difference it really makes so you know to compensate for it in future checks.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
tallpaul
Tastier than the Barrow-in-Furness bus depot...
Bike: 2016 Yamaha XT1200ZE
Re: oil level
March 21, 2015, 13:59:42 »
Good call Juv! Makes sense.
kenww
Re: oil level
Reply #5 on:
March 23, 2015, 18:40:10 »
I'm assuming all this is with engine cold?
Oop North John
Bike: DL650 M0, YB100 - 1990
Re: oil level
Reply #6 on:
March 23, 2015, 18:53:31 »
My Glee manual says run for three minutes check level after another three. Personally I check mine after filling up with fuel, and I refuel on the centre stand
Oil/Lubrication
oil level
