Author Topic: Low charging  (Read 255 times)
Offline Dewi watts
  • Bike: DL650 L3, 2013 Honda Silverwing 600
Low charging
« on: February 17, 2024, 17:01:10 »
I've got a Honda fjs600 silverwing scooter.
It's a 2013 with 29,000 miles.
A couple of weeks ago the battery was flat so I got a new one and it's been starting OK since but it's not charging high enough.
On tickover it's 12.02 volt
2,000 rpm it's 12.16
3,000 rpm it's 12.45
4,000 rpm it's 12.9
5,000 rpm it's 13.45
6,000 rpm it's 13.8
7,000 rpm it's 13.9
I checked the ac volts direct from the stator and I've lost my notes lol but I remember at 4,000 rpm it was 50 volts, I also checked the resistance between the 3 yellow wires and it read 0.2 ohms between each 2 pairs (Honda recommend between 0.1and 0.5).
I think the stator is OK so does this look like a dodgy regulator ?
Thanks for any help.
Re: Low charging
« Reply #1 on: February 17, 2024, 17:28:53 »
From what your describing,  it does look like you have a regulator issue .
Should be around 14v - 14.5v at about 5k rpm max and at tick over 13v ..
Offline Dewi watts
Re: Low charging
« Reply #2 on: February 17, 2024, 18:33:14 »
Thank you.
I just wanted to check before I parted with over a hundred quid for a new one.
Re: Low charging
« Reply #3 on: February 17, 2024, 19:09:31 »
Just make sure its made in Japan and not China...  :whistle:
Re: Low charging
« Reply #4 on: February 17, 2024, 23:17:33 »
Try westcountry windings ,see if they do one for it.
I have used them before for regs and all good and have never had a problem ,better than the std Honda jobby,don't use Electrex,if they are still going, utter shite.
http://www.westcountrywindings.co.uk/
Re: Low charging
« Reply #5 on: February 18, 2024, 08:04:41 »
   Sounds as if it could just be a bad connection,make double sure before you spend any money.
