I'm having a lot of bother with this switch. It is awkwardly placed although I have full sight of it. My standard tools end at around 22mm for sockets and spanners apart from a couple of 'used it once' specials. I measured the switch body at 24mm and bought today an open ended and ring spanner. The open ender only fits end on to the unit, impossible to get a normal fit as there''s too much too close. The ring 'fits' but the unit hex body has rounded corners so 12 point spanners and sockets won't work. There is also only 2cm clearance between the frame support for the uni-trak linkage and centrestand. (The bike is on the sidestand with e centrestand out of the way) Other parts obstruct access to get a spanner on this.
In short I need a dumpy six sided socket and hope there's enough space to get a 3/8 or 1/2 drive bar on it.
So why is this causing so much hassle? Quite simply the manual was written and this item covered when the engine was out of the frame! An assumption was then made that you only have to drain the oil, undo the old unit, screw in the new and replace the oil. In my first post I listed how much I've had to strip the bike down and now I find a 'bastard' hex body on he switch. Not a happy bunny.
