Author Topic: Aux power socket  (Read 1360 times)
Offline Whitters
  • Bike: Suzuki DL1000GT
Aux power socket
« on: April 22, 2018, 17:16:50 »
I have an auxiliary usb / cigarette lighter type socket fitted to my DL1000GT (2007) that was done before I bought it. Its wired straight across the + and - of the battery.
I'm hoping to use this to power a mini compressor / tyre inflator to inflate an airbed while camping for a week. Any ideas if this will overload the alternator or battery. I'd  probably do it with the bike running to prevent battery drain.
Re: Aux power socket
« Reply #1 on: April 22, 2018, 21:00:57 »
It should work fine but just ensure that the fuse rating is sufficient for the compressor. Just an observation though, the usb port will be a constant drain on the battery unless there is a switch of some kind to turn it off manually.
Offline James59
« Reply #2 on: April 22, 2018, 21:42:10 »
that's right, make sure the fuses can handle the device it in the socket. Mobile and GPS should be fine, other items may require a heavier load of power. I have a Cycle pump and attach it by crocodile clips to the battery with the engine running, I tested it last week and it was working fine.
