Hi all
I got the inspiration for this from this post
http://11109.rapidforum.com/topic=108775700202Hope this helps someone out there...
Fabricated brackets
Using 3mm and 2mm aluminum plate
The bottom part of the bracket I got pressed locally £20 for 1 metre length.
The others I made myself in my garage
I used JB weld to join all the bracket together
Drilled a hole and used an eyebolt so I can secure with padlock
tested the fit
bolted the bracket to the case after measuring and making sure the cases were lined up right.
used 2 aluminum bars (covered them in duck tape to stop the ali rubbing on gear)
Fitted onto bike
I used inner tube (bicycle) on the insides of the brackets to stop them rubbing the metal on the pannier frame.
During the mounting stage I used Lead sealant to waterproof the joins (tested this in my shower and it was fine) also used rubber washers.
Hopefully this will help someone
Geordie
