Exhausts
Drilled exhaust
Topic: Drilled exhaust (Read 1698 times)
jellybelly
Drilled exhaust
January 30, 2013, 22:39:36 »
Hi, a previous owner of my bike decided it was a good idea to drill the exhaust. I think its a bit too loud to be doing long distance. Is it reversible without buying a whole new exhaust? I've seen here where a disc was cut out and it was said it wasn't too loud so would cutting out a disc improve it? cheers
Locky
Bike: Triumph Tiger 800xc & Yamaha TTR250
Re: Drilled exhaust
January 30, 2013, 22:44:38 »
I wouldn't cut anything out if you want quite . Easiest option would be to weld up the holes and it should be back to normal .
jellybelly
Re: Drilled exhaust
January 30, 2013, 23:02:56 »
I might get someone to have a look at it so, do you think it would get quieter as each hole is welded. Might leave just one or 2 to hear something!
Mr Nick
Certified Fisher Price trained technician
Bike: 1979 Suzuki TS185ER, 1979 Moto Guzzi V50, 1989 Moto Guzzi SP3, 2010 KTM 990 Adv
Re: Drilled exhaust
January 30, 2013, 23:15:30 »
I'd be more worried about anything else on the bike he'd bodged as badly as that.....
Orange Bikes Matter!
Exhausts
Drilled exhaust
