I replied to the same question on the VStrom fb page.........was it you?
Yes, I have one fitted to a 2013 650. It has taken me a while to get it something like OK. solo it was fine, almost from the off, but I ride two up most of the time and when first tested it was bottoming out with both of us on it.
I have wound the preload up to give it more height and taken some off the rebound, it is now better but not perfect! It is still 'harsh' on a big bump/pothole.
I am going to get a stiffer spring fitted.
Just to make you aware, when two up, the bike is carrying close to 30 stone (I make up the most of that
It looks well made but hasn't got remote preload. You adjust it with the ring at the top and a bar. On the 2013 the frame stops you having a decent but of movement with the bar, making adjustment a pain. If you won't have to 'play' once set it'll be fine. The rebound damping is reasonably sensitive with noticeable difference with a click of two either way. It is also height adjustable, not sure by now much though.
To sum up, I would fit another if I was solo, for cost I think it's good. However two up I would spend more money and get a 'better one', I would also spend more and get one with remote preload.
