As Tallpaul says, it's the symptoms of a slave cylinder fluid leak.
Have a look in the download section and find the service manual for the model bike.
Clutch slave cylinder - disassemble/inspect/reassemble should be the sub section under brakes.
Fairly easy to do, but you are best to order a slave cylinder seal kit and change the seals first as last.
