I could not wait until I was back form my trip!
This morning I went to B&Q and bought the Dremel 200 Series Multi Tool
http://www.diy.com/nav/fix/power-tools/hobby-&-multi-tools/specialist_tools/Dremel-200-Series-Multi-Tool-10957560 and Dremel Mini Set Cutting Kit 26150688JA
http://www.diy.com/nav/fix/power-tools/accessories/drill-bits/drill_bits/-specificproducttype-cutters/Dremel-Mini-Set-Cutting-Kit-26150688JA-9288361. For some reason I paid only £40
. Best spent money ever!
I did not record what I have done because the clip already exists on youtube. I took some pictures.
Then MOD
1. Break the welds on 3 bolts securing the aluminium cover.
2. Flip the cover over and draw the area of the aluminium cover on the plate that you will cut out. After that cut the excess pipe before you start drilling for better access when drilling.
3. Drill the wholes on the line that you drew - use small drill bit (3mm, 3,5mm), it will go through easier. I used the cordless drill and had to charge battery twice.
4 use multi tool to cut the leftover metal that connects the wholes.
5. With multi tool cut out from the inside of the exhaust the inner tube. Due to space restrictions I had to cut it in two pieces. As you can see on the picture the top tube is the one I cut (nice and shiny
6. Collect all the metal bits from the inside using magnetic tool.
7. File the sharp ends on the metal plate and then mount back the aluminium cover.
I was positively surprised when I started the engine. The sound is fantastic, a lot lower and deeper. No I know that I ride V-twin.
I am not sure if the noise level is less then 94 dB but I downloaded app on iPhone and will check it later. Will post an update.
Thanks
