Author Topic: Leaking Oil Cooler Hose  (Read 6297 times)
Offline Descolada
« on: March 05, 2019, 20:06:08 »
Hi,
I started my DL650 this evening only to see a pool of oil develop as the engine was running. It looks like the Oil Cooler hose (the longer of the two - Right Hand) is leaking as a result of rust corrosion at the point where the rubber protector ends.
This hose is scary expensive and I was wondering if anyone knew what sort of pressure the oil was at as it circulates through this pipe. In short, is it worth trying to repair it? Any repair will depend on the pressure the hose is subjected to.
I understand that this is the same part as goes on the SV650, part 16460-17G00 - is that right?
Just wanted to see if anyone else had needed to resolve the same problem.
Thanks
Offline Doug McLaren
  • Bike: DL650 K6, 900 Monster, Guzzi Stelvio, Guzzi 175 Lodola.
Re: Leaking Oil Cooler Hose
« Reply #1 on: March 05, 2019, 20:33:37 »
I had exactly the same problem on my bike a couple of months ago. I just got a 2nd hand pair of oil pipes off everyone's favourite auction site and replaced the corroded one.
Offline Descolada
« Reply #2 on: March 05, 2019, 20:47:29 »
Thanks for taking the time to reply Doug. I've had to do just as you suggest and found a replacement that looks to be in good condition off beebay. It comes with the bolts and I am going to have to see if I can find the metal washer/gaskets - not sure if they will be needed, but as with the sump plug gasket, Suzuki suggest you replace with new ones. Only draw back is that it's coming from the States, it seems crazy to me that I can get this, the bolts, the P&P and the import duty for about half what I would have to pay in the UK. It's a gamble but as always, my bike is up for its MOT at the end of the month and I have to get this fixed ASAP.
« Reply #3 on: March 05, 2019, 20:53:39 »
I'm a bit late it seems, but a mate of mine took his oil feed hoses off (VFR800) and took them to a local hydrolics company who made some up for him. Can't remember what the cost was but he was happy!
« Reply #4 on: March 05, 2019, 21:42:57 »
 I forgot to get new washers for the banjo bolts and had to reuse the old ones and have had no problems, everything is all nice and dry down there.
« Reply #5 on: March 05, 2019, 23:23:51 »
Before you fit any new hoses,take the old banjo bolt seals to your local
hydraulic hose specialist and ask them for “Dowty seals” of the same size.Much better than plain copper/aluminium washers as they have a built in oil seal.
« Reply #6 on: March 06, 2019, 05:02:33 »
+1 for your local hydraulic bods.
Offline kingmunky
  • Bike: DL650 L1
« Reply #7 on: March 06, 2019, 09:09:27 »
Might be a bit late with this reply but I had the same thing, albeit the short hose instead, and the hoses from an 03-08 SV650 are a direct match. I got mine on ebay for something like £20, was used but absolutely mint condition to be fair.
Offline oslin
  • Bike: DL650A L5
« Reply #8 on: March 06, 2019, 09:14:39 »
+1 on that, I had an xj9 and the hoses were gone Yamaha wanted £130 each for them but I took them to a local hydraulic firm and they made them up for me using the existing connection fittings with a 120psi rating for £36
Offline Descolada
« Reply #9 on: March 06, 2019, 09:32:52 »
Thanks for all the advice folks. I was giving some thought to how I might limit future rust issues around the oil cooler and Oil Filter (which I have had rust through three times now - Genuine Suzuki filter). Given that I live in Scotland and we are not known for our heatwaves I was wondering about using a spray on high zinc paint on items that continually rust.
I know the other alternative is to cover everything in ACF50 or grease, but all these methods have failed in past years. Any thoughts?
« Reply #10 on: March 06, 2019, 10:08:47 »
Regular coats of ACF50. Not just once in October like some do.
My xj600 and my old k6 wee were year round bikes. Never had anything rust through with regular coatings and the occasional dab of paint on the cooler pipes.
I was doing the mileage that meant when the filter started to show rust it was due ro be replaced. I also changed oil filter every 3.5k.
The council's around here love to grit also.
But I suspect in Scotland you get slightly more. Prevention and maintenance is the key as the only cure will be to not ride the bike in the wet or salted months.
Offline kingmunky
  • Bike: DL650 L1
« Reply #11 on: March 06, 2019, 11:15:52 »
Regular and multiple applications of ACF are the way forward, takes a bit of extra time during a big wash but it works well. For the hoses, once I replaced mine I wrapped the new sections in silicone tape, making sure to cover the crimped ends fully as they seem to rust first and were the reason for my leak.
Offline Descolada
« Reply #12 on: March 06, 2019, 12:20:13 »
Could you tell me what sort of "Silicone Tape" you used, I had been considering using a self amalgamating rubber tape to produce a waterproof lining and also provide a little extra "stone chip" protection. I am, however, a little concerned about the temperature difference once wrapped and whether this might cause overheating issues with the oil.
Offline Descolada
« Reply #13 on: March 06, 2019, 12:26:52 »
I have been struggling to find anyone who keeps the '09168-14015-000 gaskets' in stock. They either want silly money or don't have enough in stock and will have to order in further delaying this repair.
So, does anyone have any thoughts on the following;
Exhibit A. The original '09168-14015-000 gaskets'
https://www.ebay.co.uk/itm/Suzuki-Genuine-Part-Gasket-14x20x1-5-09168-14015-000/382451572946?epid=651363083&hash=item590be3e0d2:g:5WoAAOSwwS1a6bQ5
Exhibit B. An alternative, Non-Suzuki, solution. The dimensions are identical but this one states "Aluminum" as the material where as the original metal is not stated. This one is considerably cheaper.
https://www.motor-doctor.co.uk/products/206232-seal-oil-drain-plug
« Reply #14 on: March 06, 2019, 13:34:36 »
Buy the cheaper one. The sizes are the same. It does the same job. :-)
« Reply #15 on: March 06, 2019, 15:31:44 »
Careful with ordering the sealing washers as they need to be the correct thickness and diameter.
Suzuki ones will be copper and the torque spec will be different.
For a dealer to order Suzuki parts they should be with a dealer the next working day if in Suzuki GB, 2-3 days if in France or Germany.
Offline Descolada
« Reply #16 on: March 06, 2019, 15:36:45 »
Yeah, I'm going to hold off on those other cheaper washers for now. They want a silly amount of money in postage. Will probably see how the ones already on the bike are when I take them off.
Offline kingmunky
  • Bike: DL650 L1
« Reply #17 on: March 06, 2019, 15:42:49 »
Not the exact stuff I used, but it's near the same:
https://www.amazon.co.uk/Everbuild-2SWELDBK-Silweld-Silicone-Fusing/dp/B007554ZI6
Good for use on temperatures up to around 250C and massive amounts of pressure; it held my old pipe together for long enough until I could get parts ordered in. Brilliant stuff, wrap it round pull it tight and it self seals almost instantly.
Edit: Where in Scotland are you? I'm in Edinburgh  :)
I had to order 2 banjo bolts and washers along with it for my repair, got the genuine parts through Robinsons Foundry and they're not copper, look the same as the ones in the advert OP linked.
Offline Descolada
« Reply #18 on: March 06, 2019, 16:38:51 »
That's interesting stuff, looks just like a silicone version of my rubber self amalgamating tape.
Quote
Dundee
Quote
Robinsons Foundry
Oh, I'd forgotten about these folks. I need to go take a look at them again.  :thumb:
Offline Silverback
  • Bike: DL650 K7
« Reply #19 on: March 06, 2019, 17:14:16 »
Had a leak on mine when I bought it...turns out it wasn't the hose,in the end it was a hairline crack along the length of the thread in the cooler itself.  No idea how or why that happened as there was no visual damage. Fleabay to the rescue once again with second hand cooler.
