Having completed a couple of hundred miles since re-commissioning an 18K mile DL1000K7 GT, those miles have shown up a couple of areas that require attention, what's those that know's suggestions for:-
Front brakes - despite cleaning the pistons (they were pretty clean and corrosion free anyway) there's not much in the way of stopping power, are there any suggested replacement calipers?
Throttle plates/butterflies - after doing the valve clearances I'll balance the throttle bodies this week, while I'm at it, should I remove the secondary plates?
Lean running - between 2500-3000rpm(ish) there's some hesitancy/surging at around those revs that makes 30 & 40mph a pain or any speed in that rev range. It's probably made worse by the K&N filter fitted by the previous owner.
I'm not that far from RJS Superbikes at Mallory Park, I've read on here that they've sorted the fuelling on a few V-Stroms but can their Yosh box also change the ignition advance for all gears so I don't have to fit a TRE?
If I do fit a TRE, which one? - the previous owner had one that he'd never fitted, I tried it but it must've been faulty as it caused a chronic misfire.
Gearing - it's on standard at present, which is way too high, I'd like to leave the gearbox sprocket at 17T but go up two or three teeth on the rear, is that enough?
Tyres - I'm quite impressed with the five year old Metzeler Tourances but the rear is squared off and has 2mm left - I'm favouring road tyres rather than 'adventure' tyres such as Michelin Road 5 or maybe Avon Storm 3DX-M, anyone any experience of the Avons?
