Author Topic: Brakes seized from ROAD salt, any way to prevent it?  (Read 1669 times)
Re: Brakes seized from ROAD salt, any way to prevent it?
« Reply #20 on: January 23, 2022, 09:26:37 »
   :thumb:  "Powerhouse" supplied top quality parts for my 31 year old VX800 brake and master cylinder rebuilds.
https://powerhouse.uk/motorcycle-brake-caliper-seal-kits/
Offline Asmith61
  • Bike: DL1000 K7, 2011 B-King 1300 , 1999 Triumph 1200 Trophy 2023 Harley Nightster 975
« Reply #21 on: January 23, 2022, 14:38:47 »
Great work pichulec    :thumb:
« Reply #22 on: January 23, 2022, 15:45:36 »
      “Powerhouse” That’s where I got my front caliper rebuild kits for my L2 from. I got them before I stripped them down,if I had known how marked the pistons were, I would have bought the kits including pistons.They cleaned up OK though with a “Dremel” type tool and brass rotary wire brush.
    Good prices and quick delivery. 👍
Offline pichulec
  • Bike: KTM 1290 SAS
« Reply #23 on: January 23, 2022, 16:19:46 »
Job done, brakes already tested, they are sharp already even that I have to worn them in. Happy 🙂
Offline colin
  • Bike: DL650 L6. v-strom 650. BMW R100rs. Harley Dyna 2000. Triumph Bonneville T100
« Reply #24 on: January 23, 2022, 18:09:14 »
thanks a lot. :ty:  I meant put rubber grease around the seals, not all over the piston
« Reply #25 on: January 23, 2022, 19:55:48 »
   There is nothing wrong with putting it on the piston, anything that catches the salt and keeps it off the piston surface is only for the good.
    I recently had a look at both of my front calipers as they were done last January and both sides still had a visible film of grease.Mind you I do wash them down with a gentle wash from the hosepipe when I wash the bike, which is every time it’s been out this winter.Brake fluid mixes with water easily so it is washed off the pistons VERY easily.
Offline Sea-Strom
  • Bike: DL1050A (2022), Fat Bob (2023), Softail Standard (2023)
« Reply #26 on: January 23, 2022, 23:28:01 »
I squirt brake cleaner all over then free-wheel bike into garage, tapping brakes slightly on the way. Always keeps brakes free and ready to roll next time out.
