Rick,are you sure you are using these plastic rivets correctly ? To remove you simply push the centre locking peg in, then pull out the whole thing.Before replacing,push the centre pin back the other way until it sticks out the other side, refit the whole thing back into its position and then push the inner in until it is flush to lock it.
