Hi gassoon
I would not ride any bike without ear plugs as it gives me a headache in a very short time.
Got the 1mm from the metal rack in Wickes as it is my nearest store, the 2mm was a swap for an old car battery from the local scrap yard last year, I knew it would come in handy sometime
I've only seen photos of Madstad brackets, do you mean the curved surface between the screen bracket and the fairing? If so that's why I made the 2nd set out of thinner material. The 2mm had no give when tightened up so I had to put some washers between, these are on my bike. The 1mm was pulled into shape which I recon is better, these are on Mrs Snowys bike, this is all part of the developement process.
The second slot at the front of the bracket isn't needed as can be seen in the photo.
Overall I'm pleased as the buffeting is now negligible, but I will try these out at the weekend if the weather allows.
viewtopic.php?f=24&t=11969&p=101302#p101302
