Author Topic: Ignition barrel key sticking/hard to turn  (Read 501 times)
Offline Gillie76
  • Bike: DL650A K9
Re: Ignition barrel key sticking/hard to turn
« Reply #20 on: May 04, 2024, 07:36:55 »
I think you may have misunderstood what I wrote - the original WD40 ie the penetrating oil, went nowhere near it!!!
It was contact cleaner (from the brand WD40)
I'd already learned my lesson previously about using WD40 on a sticky ignition barrel in my old van and was given the wrath of the locksmith when he had to come out!! 😂
Hence the contact cleaner flush out, followed by lubricating with graphite powder 👍
Offline Berty5000
  • Bike: DL650
« Reply #21 on: May 04, 2024, 22:48:38 »
Would GT85 be suitable for cleaning out or no better than WD40?
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #22 on: May 04, 2024, 23:24:52 »
I've used GT85 before, it doesn't leave a sticky residue which is better.
Offline crump
« Reply #23 on: May 05, 2024, 12:35:32 »
Silly question time coming up :)
Is graphite powder actually a powder or is it a lube made from said powder?
Offline Gillie76
  • Bike: DL650A K9
« Reply #24 on: May 05, 2024, 12:50:15 »
Crump, it's a super fine metallic like powder.
« Reply #25 on: May 05, 2024, 13:58:32 »
You can also get 'lock' lubes in a spray form.
I've used the graphite powder & it works great, however I have now stated using the spray. It costs a bit more but it lasts for a long time, if you don't forget when you put it between uses,  :roll: & a bit easier to use.
Just a personal choice.  :)
Something like this but there are others.
https://www.ebay.co.uk/itm/204767279039?epid=1907914454&itmmeta
Offline Valzdl650
  • DL650 Paderborn germany
  • Bike: DL650 K5
« Reply #26 on: May 08, 2024, 22:24:05 »
My ignition on another bike was completely locked could not turn it with either key. Used a pencil rubbed over key and ignition like brand new
