www.v-strom.co.uk/shop
Givi trekker 52L top case adaptors/support for Vstrom 650 2023
Topic: Givi trekker 52L top case adaptors/support for Vstrom 650 2023 (Read 426 times)
Gav3
Bike: Suzuki V-Strom 650
January 19, 2024, 14:15:02 »
Hello y'all
I need help,
I want to buy the givi trekker 52L top case for my Vstrom 650 cc 2023, but I'm not sure which adaptor/support I would need to get it fitted. I believe 2 pieces are required for its intallation.
Thanks for your help
Upt North
Bike: DL650 L7
Re: Givi trekker 52L top case adaptors/support for Vstrom 650 2023
January 19, 2024, 16:23:58 »
I believe you'll require a SRA3112 mount plate, but go on the Givi site and check it out. This is what I fitted with the 58 litre aluminium case.
It may instruct you to remove the thicker rubber feet before putting the box on and replacing them with the thinner ones provided, don't until you've tried it.
I put lock/nyloc nuts on the back of the strengthening support arms too.
Good luck.
Upt.
Gav3
January 23, 2024, 13:46:31 »
Thank you sir for the feedback. Much appreciated.
purplebikeunicorn
Bike: DL650A L7
January 24, 2024, 01:59:22 »
Also, be careful with Givis hardware, the screws are made of cheese, ensure your hex bits are properly seated and sized! Mine look a bit naff after having to take everything off and put everything back on to fix a broken wire.
