So...
Following on from the initial installation above, I'm after a bit of advice as to the twin nozzle mount.
Option1..
Drill and tap into the rear of the swingarm 2 X 6mm holes so a new straight bracket can be fixed from there
Do you think it would be OK / safe / recommended ?
Option 2
C bracket made from same alloy as in pic with bolt hole top and bottom to secure/clamp round swingarm, then weld a short stub to fix nozzle to (like a sort of backwards F shape) ?
Option3
Just buy shitty plastic Scottoiler mount and take the easy / uninteresting route!!
Any opinions / other ideas ?
