My Bigpie box has just arrived and my setup seems to be a little different to the instruction photos, so before I started messing with it I thought I'd check here.
The location pictured in the fitting instructions for the rear brake connector doesn't seem to match my bike (2022 650 XT). There is no orange connector in the side panel (top pic), and the only one resembling it is located down below and in front of the fuse box, almost under the coolant (bottom pic). Mine seems to match the instructions for the older models, so wondering if Suzuki moved the location again.
Can anyone confirm to me where I should connect the aux fusebox loom? Ta!
