Author Topic: Renthal 613-01 Enduro High Handlebars  (Read 1964 times)
Offline Rik
  • Username: V-Strominoff
  • Bike: V -Strom 1000
« on: August 30, 2018, 19:55:23 »
Shwmae Folks ,I have recently fitted
Renthal 613-01 Enduro High Handlebars & would like to know what Bar Ends & Handguards to order/fit or recommendations please...As I don't think I will get through winter without guards & the corks are definitely temporary!!!
Offline bako
  • Bike: DL1000A L6
Re: Renthal 613-01 Enduro High Handlebars
« Reply #1 on: August 30, 2018, 23:28:37 »
Either a set of BarkBusters, Expensive.
Or
Trip to B&Q for a long expansion bolt the same diameter as the renthals hole and with a bolt long enough to accomodate the OEM guards  and bar ends.
Or
BarkBuster do spare bar end inserts, the screwy bit that holds the bolt in, then use the OEM bolt and hand guards .
I fitted BB's to my strom and found I didn't need any barend weights. But then took em off cos didn't like em. :thumb:
Offline Rik
« Reply #2 on: August 31, 2018, 08:21:22 »
Thank you...Sometimes I set off down a path & think ,maybe I didn't think this through  ,life journey can sometimes be adventures and discovery
« Reply #3 on: August 31, 2018, 09:19:54 »
If you need bar end weights turned up I can do that, just need dims of the bar end, and bolt head.
I have been thinking of making some with a longer insert to fill with shot and silicon sealant as an anti vibe, but I need a guinea pig for an unbiased review.
Offline Rik
« Reply #4 on: August 31, 2018, 09:52:17 »
...Well there's an offer,I am very much into development /craftmanship etc... :ty:
Offline Rik
« Reply #5 on: August 31, 2018, 10:08:08 »
Renthal
Offline Rik
« Reply #6 on: August 31, 2018, 10:09:56 »
Bar End Diameter
Offline Rik
« Reply #7 on: August 31, 2018, 10:11:55 »
I will measure inside diameter of bars :fix:
« Reply #8 on: August 31, 2018, 10:16:20 »
I shall work on this, but it will not happen fast, the dimsypuhave given are very helpful, I can measure up my Veek stock bars to see how different they are. :thumb:
Offline Rik
« Reply #9 on: August 31, 2018, 10:20:56 »
 Brilliant :grin:
