Author Topic: Valve clearance check  (Read 1659 times)
Offline roganjoshing
  • Loving my first Vee Twin
  • Bike: DL650 L0
« on: February 03, 2019, 14:52:36 »
Finally took my 2010 Wee for valve check after just under 40,000 miles.  All within tolerances.  :fix:
Offline oslin
  • Bike: DL650A L5
Re: Valve clearance check
« Reply #1 on: February 03, 2019, 16:01:49 »
Thanks for that I don't think I will bother checking mine as it is at 8500 miles
Offline Holmsey
  • Bike: DL650 L9
« Reply #2 on: February 03, 2019, 16:07:42 »
I've done nearly 40000 miles without a valve check .... still the same mpg as a 2018 model over a long distance
Life on two wheels is better than 4 because the wife don't go on two wheels                " I'M FREEEEEEEEEEEEEEEE "
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline old git
« Reply #3 on: February 03, 2019, 19:24:47 »
I checked mine at 15k and 5 were out of spec. I'm fairly confident they'll still be in spec at 30k but I will check. It seems like a game of mechanical chicken if I don't.
« Reply #4 on: February 03, 2019, 20:26:42 »
I checked my K6 at 14.5k, skipped the 30k and then again when I had time around 52k.
All within spec.
Unless it's a screw and locknut jobby they generally will not need doing.
Many dealers will just say they've checked and won't even take the covers off. There's no need.
« Reply #5 on: February 03, 2019, 21:29:11 »
Checked mine at 25k, all on the minimum settings, will need doing at 30k but this is on a 1000 v.
« Reply #6 on: February 04, 2019, 11:44:00 »
These were mine at approximately 29,300 miles (attached), checked mid Jan 2017. I'm now c. 46,000 miles so looking to check them again and adjust to middle of spec.
Unsure whether to negotiate garage time with SWMBO and do them myself or to get a local dealer to do it. I've never done valve checks/adjustments before though if doing myself will need to wait for warmer weather...
Offline Mudster
  • Bike: Honda PCX125 and DL1000 K3
« Reply #7 on: February 11, 2019, 19:17:37 »
Did my Vee  a year ago. 1 valve was OK, 2 were on the minimum and 5 were below minimum. The bike had 16k on it at the time!
Shimmed all 8 to be on the higher side of clearance so I don't need to bother for a while - there was certainly more valve tap after I'd done them but I'd rather not have valves burning out.
Even if I trusted a dealer, there'd always be that nagging doubt over whether they'd really done them....
Offline mobytrip
  • Bike: DL650X K7
« Reply #8 on: February 12, 2019, 08:57:29 »
50K on mine and I have never checked, bike runs the same as when I got  it, 20K on it, not sure if it has ever been done as history was a little patchy.
Offline Salix
  • Bike: DL650 K4, 1994 Bandit 1200
« Reply #9 on: February 12, 2019, 10:58:11 »
Just did mine at around 20k, 2 exhaust on front were out of spec and all but the rear inlets were on the tight end of spec, was able to swap a couple and bought the rest of the shims but all valves are now right in the middle...the bike previously never felt right going over 60mph, now I struggle to keep it under 80! That is if I don't watch it, she just zooms ahead, wonderful change in her! Not sure if they were ever done before I bought her at 14k miles, I'm assuming not to be honest as the bloke who sold it to me told me it had had a full service with a receipt to prove, the receipt showed oil and filter and nothing else! Typical sales B.S.!
