I suspect you're right, Doctor. On the way home I started to think the bike felt pretty good. So probably was my imagination
Most likely is that having the oil changed and having 700ml more oil than before (it had been at the low mark but is now above the high one), plus new spark plugs, will have meant it did feel different in some way. Not necessarily bad, just different to what I'd got used to.
Thanks also, Diver.
I've just done the oil level check (3 mins on, 3 off) and the oil is very close to the top of the glass. There is a small air bubble at the top. I find it hard to believe this additional amount of oil, not too far above the high level mark, is going to do much harm. As pointed out by Diver, with the stupid positioning of the oil level, tipping the bike slightly one way or the other whilst I'm reaching down with a small mirror can also make the difference in how the oil level appears. On the centre stand there's a very small bubble at the top - so the level is at the top of the glass, not above it. It is useful to hear the example of the chap who massively over filled - I'm guessing he added more like a litre too much? And still didn't cause permanent damage.
There is the option to put the pipe of a spray handle, from a spray bottle, through the oil hole and squirt some excess oil out (this is an online hack for those who've over filled and saves having to empty it at the sump plug), but I won't bother. Knowing my bike and the way I ride it, the level will be down before too long.
