Author Topic: fork brace torque  (Read 231 times)
Offline EYAL400
  • Bike: bsa 500,vespa 150,mz 250,suzuki gsx 550,suzuki gsx 400,dl650.
fork brace torque
« on: August 04, 2021, 18:57:39 »
how much torque do I need to close the bolt in the fork brace ?
Ride safe .
Re: fork brace torque
« Reply #1 on: August 04, 2021, 20:13:21 »
What does the maker of the fork brace suggest?
Offline EYAL400
« Reply #2 on: August 04, 2021, 20:28:17 »
the fork brace from cosmo - greece . it was written 5 nm but it seems very low to me
Ride safe .
Online UK_Vstrom650
  • Bike: DL650A L2 White
« Reply #3 on: August 04, 2021, 21:17:12 »
The screws are tiny so I'd say 5nm is about right. Bicycles use around 5nm for their stems and seat posts so I don't think you have too much to worry about for the fork brace. Remember inner screws tightened first and outer ones second. There'll be a small gap on the outer.
Also if you remove the front wheel, you may need to remove the fork brace to get the wheel to reinstall correctly and then refit the brace - I find there's a tiny gap between the spacer and fork leg if I don't.
« Reply #4 on: August 04, 2021, 21:20:00 »
5Nm isn't much below the standard setting for 6mm screws & nuts in my old Guzzi manual I have to hand so I would go with what the chap who makes them says as he knows the material he's using.
Offline EYAL400
« Reply #5 on: August 04, 2021, 22:27:23 »
Thank you all . By the way . I didn't put locktite .  Do I need it ?
Ride safe .
Online UK_Vstrom650
« Reply #6 on: August 05, 2021, 12:46:43 »
No you don't. It might be worth putting a dab of grease on them though to help with removal if you ride in the wet.
