Author Topic: 2012 MRA touring?  (Read 3927 times)
Offline jabmotorsport
2012 MRA touring?
« on: July 12, 2012, 22:49:08 »
Now then .. I don't mind the standard screen too much but do get some slight buffeting...thinking about the new madstad bracket but of course this means another screen..
Been looking at these for a while now .. http://www.ebay.co.uk/itm/MRA-Suzuki-DL650-V-STROM-2012-VARIO-TOURING-WINDSCREEN-Windscreen -SCREEN-L-57845-/200785151065?pt=UK_Motorcycle_Parts&hash=item2ebfba4459#ht_3954wt_1202
Does anyone think this will be overkill with the new madstad or should it be fine?
Thanks in advance
Josh
Re: 2012 MRA touring?
« Reply #1 on: July 12, 2012, 23:07:46 »
new madstad on your bike means old screen (pre 2012 model)- that screen is to go on your current stock mount.
looks nice though.
I'd be tempted to get a new style madstad and have a look at these... Higher wider version
http://www.ebay.co.uk/itm/Suzuki-DL-650-1000-V-STROM-2005-2011-TALLER-SCREEN-/251095851826?pt=UK_Motorcycle_Parts&hash=item3a767aa332
the seller makes the things and they'll do them in different sizes and tints/clear. For the money you can't argue.
or the standard version
http://www.ebay.co.uk/itm/Suzuki-DL650-1000-2005-2010-STANDARD-SCREEN-/261063927967?pt=UK_Motorcycle_Parts&hash=item3cc89f689f
« Reply #2 on: July 13, 2012, 11:00:28 »
I see Mr diver thanks .. might get the older mra touring one then lol ... I've looked at the larger screen and it doesn't do anything for me but quite like the standard screen ... Cheers :)
Offline Est51
« Reply #3 on: July 31, 2012, 21:26:22 »
I have the 2011 "X" model and I really liked the look of the stock screen. Unfortunately though, at a lowly 5'7" I suffered badly from buffeting and wind noise generally. I first put a Madstad on and, although there was a bit of an improvement, I still couldn't cope without earplugs. I've just put the MRA Vario-touring on [as well as leaving the Madstad on] and it's a revelation.  I can now run it up to 70-80mph without plugs. Excellent! The only down-side is the look. The MRA isn't the most aesthetically pleasing farkle you can put on but Hello, the bike is my all-weather, any time ride, so looks are less important than max comfort. I haven't put the MRA on without the Madstad, so I can't vouch for the end result on the stock fittings.
Cheers, Steve
Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end!
Offline Dogman
« Reply #4 on: August 17, 2012, 20:41:19 »
I fitted the Suzuki vario on my new 2012 wee today. I am 5'6" and find it an improvement. Hope this helps.
« Reply #5 on: August 20, 2012, 19:55:03 »
cheers dogman .. as soon as I a can save up a bit I think I will deffinatley try something :)
Offline Dogman
« Reply #6 on: August 20, 2012, 21:36:40 »
Can I ask you what top box and plate you have on.Thank you.
« Reply #7 on: August 20, 2012, 22:44:18 »
Sure that is the trekker 52l on the givi aluminium rack :)
« Reply #8 on: August 20, 2012, 23:04:34 »
the Trekkr 52 is massive- he could almost fit his mrs in there on ST4, but her arm kept sticking out.  :shy:
I've got a madstad and would highly recommend it. not just for the fact it solves the buffeting on the older wee I have but that if the weather changes and I want to raise/lower the screen I haven't got to spend 20 mins messing around with my tool kit to adjust the height.
but I do think the old screens on the new bike may look a bit odd, but then again maybe a message to the men at Slipscreen will sort out a new style shape with the old mount points!  :shrug:
but then again the old screen on a Glee might distract you from noticing it has eyelashes!  :grin:
« Reply #9 on: August 21, 2012, 16:46:07 »
Quote from: "mr_diver"
the Trekkr 52 is massive- he could almost fit his mrs in there on ST4, but her arm kept sticking out.  :shy: :
Hahaha yes its OK now though cos got the hacksaw cracking when we got home and now she can fit init :)
At the moment I'm skint so can't do anything just yet but I would like to have a play with the screens as I do get some back buffeting from the standard glee :/ eh well hhahaha
