As Fat Rat says, plus the start button contacts.
A well known failure on that model too. The contacts that switch the lights off & back on when the starter button is pressed can burn out. You may be able to do a quick check (may not work though) before you open it up, by spraying contact cleaner into the little hole underneath the cluster.
If it is that, then fitting headlight relays will prevent it happening again.
