The problem with buying second hand sump guards... particularly metal ones, if that's what you're after, is that the bolts that hold them on also hold the engine in and the stock length bolts usually stay at the dealers.
Stick to the plastic ones and you should be OK, but they too will need the brackets to go with them.
