The DL650 17+ uses a "hook" type latch, the DL1000 14-19 uses a post style from looking at the parts diagram.
However, I'm unsure if the seat bases are actually the same, or similar enough, to simply swap the latches on the seat base to make them fit... you'd probably have to put two seats side by side to compare.
