Hello,
I've got a DL650 L0X and the rear two bolts which hold the belly pan in place under the engine have worn loose and fallen off on a ride. Does anyone know what bolts they are so I can put the belly pan back on?
The bolts that hold the belly pan to the engine bars are all intact. Its the two that hold it to the bar that is under the engine that are needed.
Many Thanks
James
