Welcome,
The AX41 is fine when matched to an AX rear...but ...they will be less grippy on the road than a purely road tyre.
If riding in the wet a lot with a pair of those , you will have to be aware and slow down a bit on the corners.
That is with a pair....with just the AX front I would be VERY careful till you get a matched pair of either type , Ax or Trailwings.
For pure road I like Michelin Road 6s, they will do easy dry trails if you are careful, shite in mud ..obvs
