Author Topic: 2011 Glee Seat  (Read 429 times)
Offline Steve T
  • Bike: F8GS, F658GS SE, G310GS Rallye
2011 Glee Seat
« on: May 27, 2025, 18:24:18 »
Silly question time with a little "lead in" info to set the scene . . .
Neighbour collected a 2011 registered Glee from south of the wall over the weekend and this afternoon he popped in by mine to proudly display his new steed . . . and very nice it is too in burnt orange, sporting a nice burbling GPR exhaust can. Anyone on here know it - registration ending in DLV?
Now, me being me, I start asking about this and taht and "what's it like under the seat?"
one-lock the seat and all seems in good order under there, so back on with the seat . . . only it won't sit properly at the front, even after ensuring the front "prongs" are correctly located under the tank support and the mid seat hokks are . . . hooked.
The front of the seat lifts nearly an inch with everything locked/located correctly, or it appears located/locked correctly at least!
Wot might I be missing with this seat fitting thing??
Over to the collective for appropriatly direct jibes and some sensible advice . . . hopefully  :grin:
Offline MisterDavey
  • Bike: DL1050 M3
Re: 2011 Glee Seat
« Reply #1 on: May 27, 2025, 18:36:46 »
I had this with my new 1050.
As much as I though it was located properly under the tank, it just wasn't.
I think I had to rest the front of the seat on the tank cover, and just gave it a good wiggle.
Remember, you can cheat death a thousand times, but death only has to win once.
Re: 2011 Glee Seat
« Reply #2 on: May 27, 2025, 19:54:59 »
Have the rubber blocks been removed or cut down?
When I took mine off, to try it as a lowered seat, it would rattle up & down like that.
I put them back on.   :)
Offline Steve T
Re: 2011 Glee Seat
« Reply #3 on: May 27, 2025, 21:07:51 »
Quote removed
Rubber blocks???
If you mean the 4 small rubber . . . rubber things, 1 sort of at each corner? Yes they were there.
Offline nigel s
Re: 2011 Glee Seat
« Reply #4 on: May 28, 2025, 06:36:02 »
My '22 650 is the same. If I don't push down on the front as I slide it forward it doesn't sit right, leaving a gap.  :shrug:
Re: 2011 Glee Seat
« Reply #5 on: May 28, 2025, 06:53:12 »
Have you thought about heating up the seat tabs and canting them or sleaving them for a tighter fit under the tank?  Maybe even increase the size of the front seat buffers / rubbers?
How about posting a few pix of the seat showing the pan underside, as well as a side view?  Try to capture a pix that shows the condition / shape of the hooks that go under the tank.
Hopefully someone might be able to spot a difference or suggest a possible solution after a gander at the pix.
For comparison I have atttached a pix of the seat pan underside view from a Glee.
Re: 2011 Glee Seat
« Reply #6 on: May 28, 2025, 07:05:23 »
2011 glee? I thought the glee started in 2012?
Re: 2011 Glee Seat
« Reply #7 on: May 28, 2025, 07:17:45 »
Possibly manufactured in the last half of 2011 for the 2012 market and early delivery to secure sales on the new generation V-Strom, with it's new motor and electronic upgrades?
Offline Steve T
Re: 2011 Glee Seat
« Reply #8 on: May 28, 2025, 08:34:53 »
Gert,
Thank you for the picture. The rectangular blocks shown on your seat are missing from my neighbours seat.
What sort of height are those blocks please?
Offline Rixington43
  • Bike: DL1000GT K7
Re: 2011 Glee Seat
« Reply #9 on: May 28, 2025, 08:47:36 »
40mm x 20mm x 15mm apparently so 15mm thick.
https://www.motorcyclespareparts.eu/en/Suzuki-parts/4514931300
Re: 2011 Glee Seat
« Reply #10 on: May 28, 2025, 11:40:57 »
Quote removed
Those are the rubber blocks I was asking about in my post.
Not sure which ones you said were there, in your reply?  :)
Offline Steve T
Re: 2011 Glee Seat
« Reply #11 on: May 28, 2025, 16:25:50 »
The 4 x small round ones, two at either end of the seat.
Thanks for the info Rixington43 re the rectangular blocks - I will pass the details to my neighbour . . . or just get him to join this forum  :thumb:
