Author Topic: Cosmo handlebar shelf.  (Read 2085 times)
Offline Beags
  • Bike: DL650 2015 XT
« on: December 06, 2017, 22:26:05 »
Hi there thinking of buying Cosmo handlebar shelf to install 12v outlets etc., I have 2015 DL650, just wondering if anybody out there has fitted one. How does it attach ? Hard to tell from pics on Cosmo website. Is it easy install etc ......... Any tips/advice greatly appreciated.
Offline Froglodyte
Re: Cosmo handlebar shelf.
« Reply #1 on: December 06, 2017, 22:53:40 »
Fitted one about 6 months ago. Really easy to fit. Take off the wire cable clamps on top yoke and fit shelf in its place
Offline Tog
  • Bike: Glee
« Reply #2 on: January 14, 2018, 18:09:04 »
I have bought one and intend fitting.  I have the voltage meter with it.  What practical use will that be for me? I'm not taking the mickey, even if it came up with some numbers I'm not sure if that would be good or bad?  I really want the USB charging facility.
Offline Froglodyte
« Reply #3 on: January 14, 2018, 18:15:31 »
A couple of months ago, I came across a chap pushing his gxsr up a hill in the Peak District . Turned out he had fitted a new rec/reg but it wasn't charging. Battery was completely flat. If he had had a voltmeter he would have seen the low voltage and avoided a lot of physical exertion!
Online Rusty Nuts
« Reply #4 on: January 14, 2018, 19:26:52 »
Exactly that. Surprising how heavy a dead bike is to push more than 20 yards.
 .......And :welcome: .
Offline Tog
  • Bike: Glee
« Reply #5 on: January 19, 2018, 10:48:11 »
Thanks for that. So what would a healthy battery display (12v battery I suppose)
What sort of numbers would indicate a problem?
I’m just weighing up whether someone with my vast experience and knowledge of electrics should tackle this. (Bullshit alert)????
Offline Ccmp
  • Bike: DL1000 K3
« Reply #6 on: January 19, 2018, 11:09:47 »
Benefit is seeing the resting voltage of approx. 12.5 volts and then seeing the reg/rectifier doing its job and delivering 14 volts when running. Really handy in my opinion.
Offline Froglodyte
« Reply #7 on: January 19, 2018, 11:10:36 »
Expect around 13.5 to 13.8 volts depending on the load. I wired my USB to the sidelight supply and voltmeter is tapped off it. Since lights are ignition controlled I don't have to worry about switching off. Also means if you switch key to parking light position, socket is live for Sat Nav setting, without starting up
Offline Tog
  • Bike: Glee
« Reply #8 on: January 25, 2018, 19:01:53 »
If this works I have attached the Cosmo Dash board Instructions for your help
