Expect around 13.5 to 13.8 volts depending on the load. I wired my USB to the sidelight supply and voltmeter is tapped off it. Since lights are ignition controlled I don't have to worry about switching off. Also means if you switch key to parking light position, socket is live for Sat Nav setting, without starting up
