Please, please only use the 'quote' button when absolutely necessary. The 'reply' button is your friend.
V-Strom specific discussion
Dreaded jerky cough and stutter between 3-4000rpm
Topic: Dreaded jerky cough and stutter between 3-4000rpm (Read 1038 times)
Garl1c
Bike: DL1000 K2
September 07, 2021, 10:07:52 »
I realise that this has probably been discussed a 1000 times but I am desperate for help as the bike is so bad it loosened the front sprocket nut with the violence of the jerking. I have a 02 1000 that I have stripped and rebuilt and I love it but every garage tells me different things and no offer of help with it. The problem I think is that the issue was pretty much sorted back in 2006 by Suzuki so I am 15 years to late for anyone to remember how it can be fixed. So I am on here to get some help, is there anyone in Doncaster or South Yorkshire or even England that can help and or look at the bike as I love it so much and don't want to put it in the back of the garage and buy something else.
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Re: Dreaded jerky cough and stutter between 3-4000rpm
September 08, 2021, 17:06:32 »
https://www.v-strom.co.uk/smf/index.php?topic=2679.0
The search function on here is rather excellent.
What has been checked so far?
Throttle bodies are a favourite for jumping off, throttle position sensors being either out of adjustment or worn would also cause your symptoms. When my TL engined device developed the "bucking bronco" characteristics it was indeed the TPS.
This video shows how to check the setting using the dealer plug, however it should be checked with the engine idling at 1200rpm and warm.
These blokes are rather good and not a million miles away if you decide you need a "tune".
https://parkitt-performance-motorcycle-racing.myshopify.com/
Garl1c
Bike: DL1000 K2
Reply #2 on:
September 08, 2021, 19:40:20 »
Thank you for the responce. I have replaced and set up the tps I have synced the throttle bodies, removed the secondries swapped the cam sensor triple checked the throttle body rubbers and connection to the air box also adjusted the fast idle. Any other ideas?
TLPower
Reply #3 on:
September 08, 2021, 20:11:03 »
I think I read on here that removing the secondary throttle plates wasn't a great idea.
https://www.stromtrooper.com/threads/do-not-remove-your-secondary-throttle-plates.59713/
I'd be tempted to refit them.
Garl1c
Bike: DL1000 K2
Reply #4 on:
September 09, 2021, 15:42:31 »
Ha ha all I read before was its better without them. It can't hurt to put them back. Cheers
V-Twin
Bike: Fantic Caballero Deluxe 500
Reply #5 on:
September 09, 2021, 21:38:09 »
On a 2006 DL1000, cured that problem with a Power Commander.
Smooth as silk now.
kwackboy
Bike: BMW F800GS Adventure, Honda CB500s
Reply #6 on:
September 10, 2021, 06:27:32 »
Here also, a K6 with a Power commander, smooth all through the rev range, never remove the secondaries unless you're fitting one.
