Author Topic: ACF50  (Read 3066 times)
Offline Moodz
  • Bike: DL1000XT Kwacker H1D RD250DX
ACF50
« on: November 26, 2018, 18:10:03 »
 :shrug:
Just spent a while coating the Strom in ACF50
Just wondered if anyone been using it for a while. I have heard very good things about it
I will keep an eye on the protection over the winter
Re: ACF50
« Reply #1 on: November 26, 2018, 18:20:23 »
Search for ACF 50 and you will find plenty about it. A lot of the members use it and give good reports.
I've used it for a few years and recommend it.
Re: ACF50
« Reply #2 on: November 26, 2018, 18:24:15 »
I use it and it will last a long time.
My bike looks like new (although it is garaged), with the usual suspect corrosion areas all looking good.
Offline wurzel
Re: ACF50
« Reply #3 on: November 26, 2018, 19:01:02 »
  I too use it, my bike is out most of the time,and has held up well against the dreaded rot.
Offline old git
Re: ACF50
« Reply #4 on: November 26, 2018, 19:20:16 »
Particularly good on electrical connectors for keeping the green gunge at bay.
Offline SuzukiSte
Re: ACF50
« Reply #5 on: November 27, 2018, 20:50:47 »
I use it also about 9 years now it’s great stuff. :thumb:
Offline The Border Riever
  • Bike: DL1000 AL9
Re: ACF50
« Reply #6 on: December 01, 2018, 22:55:31 »
Been using it for years, it goes further with a bit of sponge, or a paint brush for the awkward places!
And as mentioned earlier, Good on electrical connections!
Offline infidel
Re: ACF50
« Reply #7 on: December 19, 2018, 19:29:10 »
Its really good but nothing protects against salt eventually - Even ACF50.  I personally avoid using on electrical connectors, have heard of a few probs there - many swear by it, as do manufacturers - your call.
But one head up's from your resident industrial chemist... The safety sheets for this stuff don't do it justice. They just talk about eye safety. I use gloves, glasses, washable overall and apply in well ventilated area and don't breathe the smoke when it burns off.  (likely sulfuric, nitric acids among a host of others).
Whilst the liquid and aerosol formulae differ, ACF is essentially a Naptha solvent, and something classified in American as "hydrogenated neutral oli" - but in English we call "Lubricating oils (petroleum), C20-50, hydrotreated neutral oil-based".
This is mix of really long chain hydrocarbon oils+waxes left over from the fractional distillation process from crude. Its hydrogenated (like margarine) to produce more saturated chains. Oh and the heads-up - Its a Class 1B mutagen. Any container of it would have to have the carcinogen label and "May Cause Cancer" in clear lettering. Its 70% of the formula and 100% when its dried on. So wash it off first!!
Naptha's fairly safe unless you drink a can, likewise the 1,1-difluoroethane in the aerosol version unless you sniff the whole can. (good luck with that).
Why it works? Not my area of expertise (lubricants) but here's my guess/
Its an oil, and very water repelling, especially the longer chains which are more wax like than oil like. The C20-50 oil is high viscosity and I'm guessing really crap flow properties meaning it sticks well to the parts coated and won't 'run-off easily'. The hydrogenation process creates Lots of saturated double bonds, meaning this oil oxidizes/peroxidizes very quickly once it gets going - and catalytically so in the presence of metals. Hence this acts as a 'corrosion sink'.. The oil coating gets super oxidized and rancid (like off butter) as a sacrificial oxidizing agent. Any Oxygen would rather react with the oil than the metal it coats and before the oils is spent oxidizing you have probably washed it off and re-applied.
Everything else is a solvent.
Genius.
PS saftey data sheet here http://www.acf-50.co.uk/acro2017/10013%20ACF-50%20%20AEROSOL%20MSDS%20_%202017%20_%20ENGLISH.pdf
Offline Mark Shelley
  • Bike: GW250 SV650N
Re: ACF50
« Reply #8 on: December 19, 2018, 21:58:30 »
Holy sh1t, that sounds really complicated. Does that mean it is a bit like liquid galvanizing?
Offline infidel
Re: ACF50
« Reply #9 on: December 20, 2018, 15:33:26 »
spot on - but with a clingy saturated oil/way vs a dip in zinc.
Offline Relevant11
  • Bike: Dl1000L4. KTM XCF 350, Royal Enfield interceptor 650( yes they are as good as they say)
Re: ACF50
« Reply #10 on: December 20, 2018, 22:42:26 »
 Great info infidel , a most informative post  :bow-blue:
