Author Topic: Repair kits  (Read 360 times)
Offline Rookie
  • Bike: DL1000 K7
Repair kits
« on: April 14, 2024, 20:18:06 »
Evening all, I've just completed a front brake system rebuild over the weekend. Forced job really as I hadn't realised just how badly corroded my pistons had become. But a TRK kit and hel brake lines have worked wonders.
Now question of the day is, I'm due to do the same to the clutch side next weekend and I wish to replace the mastercylinder internals. I've failed to find a kit to do so.
Does anyone know if the kit for a front brake master cylinder is useable for this, as visually it would appear so. Plus I don't won't to take things apart without being able to rebuild it.
The bike is a K7  Vee
I would love to post some photos, but I have enough trouble trying to explain myself at times
Cheers then.... :fix:
That ain't rain it's liquid sunshine 🌞
Offline Rookie
  • Bike: DL1000 K7
Re: Repair kits
« Reply #2 on: April 14, 2024, 21:34:16 »
No  lol
Offline Mojo-Jojo
  • Bike: DL1000GT K6
Re: Repair kits
« Reply #3 on: April 15, 2024, 02:13:42 »
Online Rixington43
  • Bike: DL1000GT K7
Re: Repair kits
« Reply #4 on: April 15, 2024, 09:30:06 »
OP mentions master cylinder for clutch, the OEM kit (which you've probably already found) is here;
https://www.motorcyclespareparts.eu/en/Suzuki-parts/5980008810?_gl=1
It's definitely different from the front brake master cylinder set as the piston looks a substantially different length from photos.
I've seen a few after market kits on eBay a bit cheaper but not enough cheaper to not use the OEM personally.
Offline purplebikeunicorn
  • Bike: DL650A L7
Re: Repair kits
« Reply #5 on: April 15, 2024, 11:55:52 »
Here is a kit for the GSF1250, and it lists compatibility with the DL1000 (found by finding the all balls kit and searching the compatible bikes)
https://www.ebay.co.uk/itm/116050496313
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
Re: Repair kits
« Reply #6 on: April 15, 2024, 21:13:08 »
I think you may need to go to page 10 for compatibility. Well done to all you members, you are what makes this site so great.  :thumb:
Offline Rookie
  • Bike: DL1000 K7
Re: Repair kits
« Reply #7 on: April 18, 2024, 18:56:41 »
Thanks everyone for their replies, I think @Rexington you've hit the nail on the head. That and the refurbished slave cylinder I purloined of @kwackboy last year all should be good  :thumb:
