Fitted a set to my Wee yesterday.
Coming from a set of fairly well worn (~2mm front and back left) anakees... Loads of tread, the bike sits a cm or so higher, and they look great (very important, of course!) First ride was on warm damp (greasy) roads at first which then just got wet, so not an ideal first go!
The front's quite vibey below ~25-30mph, but that's no issue, and it disappears above that. It does howl a lot, especially under braking passing through 35-40mph, but meh
I did feel the back moving to and from that central band, which made me feel a bit twitchy, but I've either become used to it already, or it's gone along with the release compound, as turn-in's are now smooth. Plenty of grip there too! (Although I can get black lines from both ends under hard braking (abs active)
I'm happy, and it sounds like things will get better as they wear in
Currently running 25/30psi (fr/rr, solo) but forgot to check my warm pressures this morning, so I'll be fiddling over the coming week.
