juv what tyres would give the best mileage not worrying about performance?
I wouldn't say I can pin this with accuracy, but it seems as if it would be a toss up between the Anakees 2 and the Heidenau K60.
According to my service records I'm on my 3rd Anakee 2 rear tyre. The first two gave 15868 and 20610 miles respectively. The current one has plenty of life in it, has done 10726 miles now and I expect at least another 5-7k out of it. If you average the mileage I got out of the first two tyres you get 18239. I must add that I do ride them until the middle of the tyre tread blocks are level with the carcass, some people will change them earlier, you can probably take about 3k off for that difference.
I'm on my 2nd front Anakee 2, the first one did 24151 miles, and the current one has done 7185 and it's still looking near new. I expect this one to last roughly 24k again.
My opinion after much testing is Heidenau K60 Scout. But they perform real well as well as lasting
Two sets so far on this current trip
1st set 24,000km
2nd set at around 18,000 this set won't last as long because Mongolia tore the crap out of them
If we use TravellingStrom's K60 figures for comparison then and convert them to miles:
1st set: 14913 miles
2nd set: guesstimate of 11185 miles
I'm pretty sure TravellingStrom is much harder on tyres than what I am. He's loaded up and going on much worse roads than what I use. I sit on a motorway at a relative constant speed most of the time which will add to longevity. Also note that the Vee will get less out of a rear tyre than a Wee because of the extra power.
I haven't used the PR3 tyres, maybe frez can give his numbers, he done some high mileage on them so his figures would be comparable.
As for Maxxis tyres, if you're on about the Presa Detour ones, LaKraven, then I have to disagree. They were pretty good in the grip department. The front lasted 21k (off the top of my head), but the rear was squared off so that it could stand up on it's own by 7442 miles (I replaced it with an Anakee then.) I'd imagine if I had a Vee that would have been in the region of 5k instead. They are cheap, but you'll have to replace that rear sooner than if you had an Anakee/Heidenau which would probably end up being more expensive? I think you were good at sucking every last mile out of them or I got ones that were just crap to start with?
