I just wanted to give a well deserved THANK YOU to all who contribute on this forum......
I've had two problems with my Glee over the last month and both were solved quickly, cheaply and pretty simply!!
Issue No 1Very occasionally the bike would not start, not even an attempt from the starter motor. Then 1 minute later it would start faultlessly. After a quick search on here, figured it was likely to be the clutch switch, ordered a new one, swapped it out and abracadabra problem sorted
Issue No 2Last night after meeting up with a few mates, went out to the bike, started her up and no headlight or main beam, absolutely nothing. Everything else was fine. Checked the fuses and all seemed OK. Decided to make the short trip home just using the side lights
Had a quick search on the forum this morning and a previous suggestion was it was likely the starter switch had got stuck. Just finished taking it apart, giving it a good clean and some TLC and abracadabra problem sorted
