Tyres
2 Rear to 1 Front?
Topic: 2 Rear to 1 Front? (Read 2314 times)
Joe Rocket
Bike: DL650A L5, Kawasaki GPX750R
2 Rear to 1 Front?
June 04, 2017, 08:24:29 »
Just thought I'd ask your opinion on whether the ratio applies to any of you when needing to change tyres.
I need to change my Anakee 3s as a pair as there is little difference in rates of wear to both tyres. Both my brothers think the rear should wear out twice as quick and I must admit that used to be the case on my bikes in the past.
Put it another way; is the rear designed/manufactured to last as long as the front? A Michelin thing or common across all the makes?
UK_Vstrom650
Bike: DL650A L2
Re: 2 Rear to 1 Front?
June 04, 2017, 08:55:06 »
My front A3 went off before the rear one on the Strom... I tend to change Strom tyres as a pair
Fat Rat
Administrator
Bloke/Geezer/Fella
June 04, 2017, 10:58:29 »
I also change in pairs.
Unless one gets damaged after a few hundred miles
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
Willie Fawcett
Bike: DL650XT L5, 2014 Suzuki GSX-S750, Honda MSX125SF
June 04, 2017, 19:29:43 »
The metzeler tourance I use on my 650 last aprox 4500 to 5000 on rear & 11000 to 12000 on front . I usualy change them one at a time when worn out .
chris1200
Bike: 2008 V Strom 650.
June 04, 2017, 19:56:25 »
Strange. My fronts always last a lot longer then the rears.
Rusty Nuts
Manufacturer of iron oxide
Reply #5 on:
June 04, 2017, 19:58:33 »
Mine too. Just having a second rear fitted this week, front's fine. ( PR4 )
Angustoyou
Bike: 2013 Glee
Reply #6 on:
June 09, 2017, 18:15:44 »
Anakee 3s on mine too, easily 2 rears to a front. I change one, then the pair, though if I was tight I could run the front longer. It is the main water shifter though...
Sasquatch
Bike: DL650GT K9
Reply #7 on:
June 12, 2017, 20:28:05 »
It's all down to right wrist twist rate.
Joe Rocket
Reply #8 on:
June 13, 2017, 08:26:44 »
I suggested to my brothers that maybe riding 2 up all the time would be a factor......far more braking required/load on the bike....what do you think?
Tyres
2 Rear to 1 Front?
