Local dealer quoted £205 for mine last week. Turned out they cocked up and didn't have the plugs in stock! They told me, realistically 7500 is too early, and did the service excluding plugs for £140. On challenging them, the service bloke said 7500 is too early! I accepted and asked that the plugs be removed and gap checked etc be informed that the mechanic knew "by the sound" that the plugs were OK! I've an extended warranty and was a bit concerned about not having the plugs done, but, unless a plug breaks and screws the engine, I'm working on the assumption that it shouldn't be a problem! I have to say, the oil change worked wonders for the gear change! Snick, Snick now
