Hiya after some advice please.
I have changed my vstrom suspension around to increase ground clearance on my wee. I had the original side stand extended by a work college who did a bit of welding. He hasn’t done a great job, as the weld cracked after not a huge amount of use. Anyway he took it back to sort out and I am half convinced he has lost it.
So I potentially need to replace it but if I am doing that then I makes sense to try and buy something long enough.
I added nearly 4” to the side stand to make it lean at a sensible angle. So does anyone know of a bike with the same sort of top mount but significantly longer?
Thinking drz, XT660, Tenere, AT…..
Thank you for your help!
