Author Topic: Adjustable side stand.  (Read 1289 times)
Offline Rogi
  • Bike: DL1050XT
« on: December 27, 2021, 16:46:19 »
What have you done to your kick stand following lowering the bike? Anyone have thoughts or used adjustable kick stand.
Re: Adjustable side stand.
« Reply #1 on: December 27, 2021, 17:05:48 »
All the adjustable ones I've seen are made of the finest Chineseium and are guaranteed to snap on the first use.
Generally the best option is a second hand one and have it cut down.
Offline Rogi
  • Bike: DL1050XT
« Reply #2 on: December 27, 2021, 17:43:51 »
I concur. Cheers
Offline colin
  • Bike: DL650 L6. v-strom 650. BMW R100rs. Harley Dyna 2000. Triumph Bonneville T100
« Reply #3 on: December 28, 2021, 18:47:33 »
Cut the foot off.  cut a section out of the stand and weld the foot back on
Offline Rogi
  • Bike: DL1050XT
« Reply #4 on: December 29, 2021, 09:40:57 »
I'm buying one from Cosmo just incase I  ###it up!!!
« Reply #5 on: December 29, 2021, 11:12:58 »
I'd slug it internally too, if I was doing that.
Offline colin
« Reply #6 on: December 30, 2021, 12:33:16 »
no need to slug it. I haven't cut the shaft. just the flat foot off the end. then cut about 3/4" of the length and weld the flat foot back on.
« Reply #7 on: December 30, 2021, 14:27:29 »
 :thumb:
I see. The only ones I've seen were cut part way.
Offline Graham62
  • Bike: DL650 K6 Blue
« Reply #8 on: January 11, 2022, 19:32:22 »
I had mine cut down and the foot welded back on, I've now put the bike back to standard.
Graham
Offline davef
  • Bike: 2010 V-Strom 650 AL0
« Reply #9 on: January 16, 2022, 17:36:24 »
I filed the side stand stop so the stand swings a bit further forward - this in effect shortens it and makes the bike less likely to roll forward off the stand.
« Reply #10 on: January 17, 2022, 05:44:48 »
Care to share any pix and advice, should anyone else want to follow your example, with regards the side stand stop modification?
Offline davef
« Reply #11 on: January 17, 2022, 17:55:19 »
The sidestand swings forward till it hits a square steel stop. I filed this stop till I was happy with the lean angle - nothing complicated, just a bit slow. If the bike was to be reset to normal height suspension, its only 2 bolts to take off the side stand assembly when a spot of weld could be put back on the stop to take it back to normal.
« Reply #12 on: January 18, 2022, 06:37:38 »
Thanks for your reply. I did read something similar wrt a side stand / kick stand mod for a more stable lean angle, in https://www.stromtrooper.com/threads/kickstand-modification.432423/. From those pix posted, it appears that the mod in the Stromtrooper thread, may perhaps allow for a bit more lean angle than that of your mod of the stand stop. Without your pix to reference, I could be mistaken. Hence the request for a pix or three, for better understanding.
