Electric gremlins have struck!!
The ignition fuse on my bike keeps blowing. It started on Sunday afternoon, 10metres from home the bike dies and I get the 'CHEC' message on my dash. Push the bike home, quick check of all the cut off switches (side stand, clutch, engine kill), no apparent problems there, check the fuses, ignition fuse blown. Change fuse, blows again immediately. If I turn the ignition on with the engine kill switch in the off position the fuse will only blow when the switch is flicked to on.
I've stripped the bike down today and can't find any worn/discolored wires, everything looks brand new.
Checked the wiring diagram in the workshop manual and after the kill switch you have two coils, the fuel pump relay, the ECU and the dealer mode plug. Have checked all the connections re-seating most and can't find an issue.
Any help appreciated....
(Electrics scare me, mechanically I could rebuild my bike but anything electrical I panic....help!!)
