All day yesterday refitting the refurbished carbs and new plugs leads and caps. Balancing the carbs was tricky until I discovered I had not fitted a spring where a spring should be. A slight misfire was cured when I realised one plug cap was not pushed fully onto the plug. This morning I took it on a 60 mile run up to Norfolk to see a friend only to have it stuttering like a stuttering thing until I switched it from main to reserve. Then all was well until I went to a garage and topped up with Shell unleaded which at £1.32 per litre is approaching the cost of angel's tears. And then it started stuttering again as I had forgotten to turn the fuel tap to on. Something that does not have be faffed with on a modern bike. Owner stupidity aside the bike runs fautlessly although I don't rag it and tried to keep it at 58mph . One thing I did notice is just how good the front suspension it. It floats over the bumps and ridges that on other bikes are spine, neck and teeth rattlers. Oh! and another user error was when I fitted the Sat Nav and powered it with a relay wired to the rear light as a trigger. Yeah !.... it doesn't power up until I switch the lights on Doh!. All that aside it is such a lovely bike to ride on a sunny Bank Holiday Monday.
