Author Topic: Glee (plus others) L1 to L6 SW Motech gear change lever...  (Read 368 times)
Offline crazyhorse
  • Bike: DL650 L2
« on: February 01, 2024, 18:20:14 »
Hello
I have, for some strange reason, two of these SW-Motech gear change levers which are slightly adjustable for those of us with big boots/tootsies!!!
The difference between the two is the the first one has a larger/longer toe "lever".
I would like £50 for either one, plus P&P.
Crazyhorse
Offline crazyhorse
  • Bike: DL650 L2
Re: Glee (plus others) L1 to L6 SW Motech gear change lever...
« Reply #1 on: February 16, 2024, 11:59:12 »
Bump.
« Reply #2 on: February 16, 2024, 15:08:31 »
Hello crazyhorse. I have a DL1000 2014 and if the gear lever with the slightly longer toe piece will fit my bike then I would very much like it please. Can someone confirm it will fit please, I think it will. First dibs please crazyhorse until a definite answer as to fit.  :thumb:
Is the original bolt used to fit it?
Offline crazyhorse
  • Bike: DL650 L2
« Reply #3 on: February 16, 2024, 18:22:36 »
Hi Doc
The pivot point for both models you mentioned have the same Suzuki part number, and held on with the usual circlip.
I can only assume that the SW gear lever will fit, but the angles for the lever might need some adjustment.
What do you think?
Crazyhorse
« Reply #4 on: February 16, 2024, 21:55:28 »
Thank you. PM sent.  :thumb:
Offline crazyhorse
  • Bike: DL650 L2
Re: Glee (plus others) L1 to L6 SW....NOW SOLD
« Reply #5 on: February 25, 2024, 15:22:42 »
Hello
This item now sold.
Crazyhorse
