Author Topic: Optimate connection  (Read 193 times)
Offline jimi28smith
  • Bike: DL1000 L8
Optimate connection
« on: August 05, 2021, 06:28:00 »
Hello all, I’ve got an optimate which on previous bikes I’ve plugged in through the 12v socket. On those machines the 12v socket was an open circuit (not turned on and off by the ignition) and was made for the propose of trickle charging.
Does anyone know if the same is true of the 12v socket on the 2018 Vstrom 1000? Has any one used it for this? Thanks
Offline STORMY
  • Bike: DL1000A8
Re: Optimate connection
« Reply #1 on: August 06, 2021, 00:58:27 »
It’s not an open circuit and is defiantly switched off with the ignition, we’ve got the same bike,  I ran a fly lead from the battery that exits just near the seat on the left hand side.
Doubles as a power supply for heated clothing in the winter if you use that sort of thing, and when not in use has a rubber cover that closes off the connector (Sportsbikeshop do them)
If you ignore your teeth, eventually they’ll go away
  • Bike: VX800: KTM 390 Duke,
« Reply #2 on: August 06, 2021, 11:45:37 »
The  battery fly leads cost about £9.90 I have also seen them used to power heated grips or to power a Satnav.
