Author Topic: Any Plumbers in?  (Read 253 times)
  • Bike: DL650A L6
Any Plumbers in?
« on: May 05, 2021, 19:06:42 »
I need some tips please.....
I am bringing water to my new (outside) Toilet/Shower using 20mm Alkathene. I don't really want to take the Alkathene inside the building. What I would like to do is have a neat through the wall solution which converts from Alkathene to (either) 15mm copper or plastic push fit pipe.
Any elegant solutions?
** Biker Friendly Campsite in West Wales **
I will NEVER use JT's Motorcycles of Swansea! http://www.v-strom.co.uk/smf/index.php?topic=2717.msg205443#msg2054
  • Bike: KTM 1090
  • Bike: DL650A L6
Re: Any Plumbers in?
« Reply #2 on: May 05, 2021, 19:17:05 »
Did you mean to post that in a 2 point font?  :old:
I'm good with adapting from Alkathene to 15mm but I was wondering if there was a neat through the wall solution  :thumb:
Online mr_diver
  • Bike: 'onda Varadero XL1000v9, 'onda CX500ec '83, Yam XJ600n '96, GSX14 '06, DL650 K6 (Blue) R.I.P,
« Reply #3 on: May 05, 2021, 19:25:29 »
A drill?  lol
Sorry had to be done.
  • Bike: KTM 1090
« Reply #4 on: May 05, 2021, 19:31:43 »
Re: fonts, whenever I paste a link it always defaults to tiny. I forgot to re-format it that time.
Offline Hugo Magnus
« Reply #5 on: May 05, 2021, 19:45:55 »
Is this because you were in such a hurry to get the concrete down you forgot to bring the water pipe up through the floor? :grin:
  • Bike: DL650A L6
« Reply #6 on: May 05, 2021, 20:02:54 »
 :grin: That is definitely something I would do, just not this time.
When I did the last Showers it was easy because there is a Kitchen area at one end and bringing an ugly blue pipe up through the floor was okay. Because the new building is only a single toilet/shower, I was hoping for something more elegant.
Offline Dark-Strom
« Reply #7 on: May 05, 2021, 23:58:22 »
Normally we run a duct in a concrete base from outside to inside at 90 degrees and then cut off at ground level inside and seal with the appropriate material, in your case expanding foam etc.? :shrug:
May your God go with you...
(Dave Allen)
Offline Dark-Strom
« Reply #8 on: May 08, 2021, 09:31:18 »
Also, in the past on water supply instrument installations we go from 20mm blue poly into a female threaded plasson adaptor into a male threaded pvc glue-in adaptor and route / clip the pvc pipe to close to where needed, before changing to final choice, I.e. copper or plastic?  :shrug:
(Dave Allen)
